Hi there,
currently I am a little lost with the template programming for a Samsung LCD panel.
I have a 1.34a Beo5, 1.30 config tool, the Lintronic Software and the Beo5 3rd Party XML generator ...
I dont know how much time I've spend on remotecentral.com to find codes for my Samsung LCD LE52M86, but I couldn't find any. The ultima ratio for me would be to buy a Lintronic or IRtrans box to capture the codes from the original remote but I am not sure if that would work as I think it should :-)
I tried the generic RC5 protocol but it didn't work, do you know what protocal Samsung uses? (Couldn't find anything on their website)
Any help is appreciated :-)
Best
ultra
