Latest post 01-10-2009 11:40 AM by Keith Saunders. 6 replies.
Page 1 of 1 (7 items)
  • 12-16-2008 5:14 AM
    help whit XML file (HYUNDAI, SAT RECEIVER, HSS820)
    got those code from Lintronic and i wonder if you can make it whit this( XML files to control Beo 5.)??
    Does anyone have any ide if i can do that??
    Regards Claudiú
    LinTronic CommandFunction
    7130010140000000000000
    7130010010000000000001
    7130010020000000000002
    7130010060000000000003
    7130010040000000000004
    7130010050000000000005
    7130010070000000000006
    7130010080000000000007
    7130010100000000000008
    7130010110000000000009
    713001026000000000000AUDIO
    713001019000000000000CH.LIST
    713001022000000000000CHANNEL.DOWN
    713001021000000000000CHANNEL.UP
    713001030000000000000DECODE
    713001018000000000000ENTER
    713001017000000000000EXIT
    713001024000000000000GUIDE
    713001031000000000000HDD.DEL_SKIP
    713001009000000000000HDD.LIST
    713001032000000000000HDD.MENU
    713001028000000000000HDD.RECORD
    713001025000000000000INFO
    713001016000000000000MENU
    713001003000000000000MUTE
    713001000000000000000POWER
    713001013000000000000PREVIOUS
    713001029000000000000SLEEP
    713001012000000000000TV_RADIO
    713001015000000000000TV_SAT
    713001020000000000000VOLUME.DOWN
    713001023000000000000VOLUME.UP
  • 12-16-2008 9:25 AM In reply to
    Re: help whit XML file (HYUNDAI, SAT RECEIVER, HSS820)
    Happy to see you've finally fixed THIS problem you had some days ago...
    ...by the way, don't mention it ! Wink
  • 12-28-2008 10:33 AM In reply to
    did you solve this problem? got the same problem, but other devices ;)
  • 12-28-2008 3:20 PM In reply to
    no i did not fix my problem, and i dont have any ide if it can be done, does anyone know?
    thank you very much
    claudiu
  • 12-30-2008 2:46 AM In reply to
    Claudiu,
    All Hyundai STB's use standard NEC protocol IR codes and so an XML file can be made for this product without much trouble. The Lintronic codes you listed start 713 meaning NEC.
    Send me a PM as a reminder, but in the next week I will put one together for you to test.
    Regards Keith....
  • 01-08-2009 10:56 AM In reply to
    Thank you very much that you will help me to make this xml file for my hyundai setup box.
    Regards Claudiu
  • 01-10-2009 11:40 AM In reply to
    I have sent you a PM with a download link on Friday
    Regards Keith....
