I HAVE A BEOCENTER 7700 THAT POWERS UP BUT DOES NOTHING JUST THE LEVEL DISPLAY IS SHOWING. THE POWER SWITCH DOES NOT SEEM TO WORK. IS THERE A SAFETY SWITCH THAT IS OPEN?
CHRIS
Chris,
Perhaps you can give more detail, other than the level display, is there anything else whatsoever which shows signs of life ?
What makes you think the power switch does not seem to work ? given you apparently have life in the level display.
Regards Keith....
