Hello,
Unfortunately the codes are different. M3000 is the first generation of Tvix.
I have a 5000HD in the main room, controlled with Beo5 through the PUC of the BV9.
I want to use the M3000 in a link room rather than "ebay" it.
The question remains open.
Thanks anyway,
Yann.
Ne pas s'en faire et boire frais!
Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
