i got those code from Lintronic and i wonder if you can make it whit this XML files to control Beo 5.
Does anyone have any ide if i can do that.
Regards Claudiú
LinTronic Command | Function |
713001014000000000000 | 0 |
713001001000000000000 | 1 |
713001002000000000000 | 2 |
713001006000000000000 | 3 |
713001004000000000000 | 4 |
713001005000000000000 | 5 |
713001007000000000000 | 6 |
713001008000000000000 | 7 |
713001010000000000000 | 8 |
713001011000000000000 | 9 |
713001026000000000000 | AUDIO |
713001019000000000000 | CH.LIST |
713001022000000000000 | CHANNEL.DOWN |
713001021000000000000 | CHANNEL.UP |
713001030000000000000 | DECODE |
713001018000000000000 | ENTER |
713001017000000000000 | EXIT |
713001024000000000000 | GUIDE |
713001031000000000000 | HDD.DEL_SKIP |
713001009000000000000 | HDD.LIST |
713001032000000000000 | HDD.MENU |
713001028000000000000 | HDD.RECORD |
713001025000000000000 | INFO |
713001016000000000000 | MENU |
713001003000000000000 | MUTE |
713001000000000000000 | POWER |
713001013000000000000 | PREVIOUS |
713001029000000000000 | SLEEP |
713001012000000000000 | TV_RADIO |
713001015000000000000 | TV_SAT |
713001020000000000000 | VOLUME.DOWN |
713001023000000000000 | VOLUME.UP |
