Latest post 12-14-2008 2:31 PM by beo4me. 6 replies.
Page 1 of 1 (7 items)
  • 12-11-2008 5:02 AM
    beo5 config questions
    Hi all,
    I am in the process of changing the original config of the beo5 that my dealer did. I have a couple of points where I am stuck and hope someone here can help me with:
    1. I want to create a macro that on the press of a button would create a Picture in Picture with my HDR1 in  V.TUNER mode. On my beo4 I would press P-IN-P and the red button (or scroll down in the menu and press OK), but I cannot find the P-IN-P command in the IR list of the config tool.
    2. Can I use the command P.Mute (PICTURE_TOGGLE) to have sound, but no picture? I always used AV - TV on my beo4.
    3. How do I create the AV - V.AUX combination in one button?
    4. Is there a list that explains all the commands in the IR list?
    Thanks,
    Frank
    Filed under:
  • 12-11-2008 6:11 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: beo5 config questions
    Interesting questions!!!
    I would love to have the answers as well.
    However, if I remember correct, there is a list of commands on the user manual of Beo5 where there is a comparison of Beo4 to Beo5. Have you already checked it?
    Best regards
    Spiros
  • 12-12-2008 12:51 PM In reply to
    I did check the list, but this is for how to operate the remote, not for the configuration tool.
    Cheers,
    Frank
  • 12-13-2008 4:49 AM In reply to
    • Luigi
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Figueres (Spain)
    • Posts 3,013
    0:000:Radio:TV
    0:000:Radio:Aux_V
    Luis
  • 12-13-2008 12:36 PM In reply to
    Maby I have the answer for the P-in-P. I use it with an Avant with a PIP module build in.
    I have used the following commands (all seperate icons):
    P-in-P 0:000:TV:PICTURE_IN_PICTURE
    (green button) Upper left 0:000:TV:CNTL_REWIND
    (red button) Bottem left 0:000:TV:CNTL_STEP_DW
    (yellow button) Upper right 0:000:TV:CNTL_WIND
    (blue button) Bottem right 0:000:TV:CNTL_STEP_UP
    Change picture (PIP and TV) 0:000:TV:CIFFER_0
    Your problem is the first line (0:000:TV:PICTURE_IN_PICTURE) because the command PICTURE_IN_PICTURE is not in the list. Just type the command. It will work.
    I want to show you the screen of my PIP page on the BEO5. But I don't know how to add a picture in this message. So you have to do it with the commands only.
     Piet
  • 12-14-2008 6:42 AM In reply to
    Hi Luis and Piet,
    Great stuff, seems I have everything together now. Coming back to my last question: Is there a list available for the commands in the tool (and others, see PIP) or have you done this by try and error?
    Cheers,
    Frank
  • 12-14-2008 2:31 PM In reply to
    I have found how to look at the existing configuration and display commands. I should have got this earlier, but I am just getting to grips with the tool Embarrassed In the config tool the commands are shown in the view menu when a button is pressed in the model of the Beo5. In there the PICTURE_IN_PICTURE command shows up, when I press the pre-configured buttons after addition of the HDR.
    Cheers,
    Frank
    Filed under:
