Latest post 12-09-2008 6:31 AM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 12-09-2008 3:13 AM
    Will UK spec Beolab 3 speakers work in Canada?
    Any advice/experience welcomed. I have searched around and checked out the specifications here;
     http://www.bang-olufsen.com/UserFiles/File/ts/BeoLab3_en.pdf
    but have not been able to find an easy answer.
    I will be spending a fair amount of time indoors avoiding the freezing Winnipeg winter and would like to take my British Beolab 3 speaker. But will they work with a Canadian power supply?
    Thanks.
     Ben
    ------------------------- Looking forward to the Summer!
  • 12-09-2008 3:34 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Will UK spec Beolab 3 speakers work in Canada?
    Hi
    No, they won't just plug & play' as the voltage in Canada is different to the UK.
    You can either use a voltage converter (see our FAQ section article on them) or your engineer can do a simple tweak to the 'insides' for them to run on 110v.
    Lee
    Smile
  • 12-09-2008 6:19 AM In reply to
    Thanks for that. A transformer seems a lot of hassle so maybe I will just buy some cheap speakers in Canada to see me through.
  • 12-09-2008 6:31 AM In reply to
    The job cannot take more than I hour. It's only a question of adding a jumper to each speaker. Easy for any service technician
    Regards Graham
