Latest post 12-04-2008 4:20 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 12-03-2008 9:04 PM
    replacement parts for Beolab 3500 speaker [pre 1999]
    I have moved and lost parts to this speaker, and one of the fabric panels is damaged. I am very low tech, so please help.
    I can't find what plugs, cables etc go with this speaker, or the pedestal for using it on a table. How do I locate and buy these? Also, is there a way to fix the panel or find a new one?
    Thanks so much for your help.
  • 12-04-2008 4:20 AM In reply to
    Re: replacement parts for Beolab 3500 speaker [pre 1999]
    Your local B&O dealer will be able to help you.
    Regards Graham
