Latest post 12-04-2008 2:21 PM by stotty1111. 6 replies.
Page 1 of 1 (7 items)
  • 12-03-2008 7:13 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Mx7000 - Sat module
    Hi all
    Mr Stupid here again - recently got hold of the above tv with a satellite module in it - details from stickerare
    RTT / ROSAT / D / 0109
    obviously of German origin as other details are in German.
    The pcb panel has the following DIN outlets labelled
    Mac Decrypt                         T C Output
    Video decoder                       Audio decoder
    Outdoor control                      Actuator control
    RF female socket 75ohm
    Is this analogue or digital - any brochures/ manual available to direct me as to its use or is it not possible to use it?
    When hooked up to the dish and a manual scan of channels, the screen does react (ie from snowy like to solid black/grey however sound is still white noise )
    HELP please!!
    salut
    t o n yConfused
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 12-03-2008 8:34 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: Mx7000 - Sat module
    Stupid me !, now stumbled across the manual for the Bsat lm module - will try to follpow it later - hope i'm successful!
    t
  • 12-03-2008 12:47 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Back to the drawing board kids!
    Can't get the tvin sat mode to work - when sat pressed >menu etc decoder on black screen set it scanning (betwwen approx 10800 and 11600) doesn't find anything - sat dish ok as works with a freesat box and also a sky box voltage output at rf socket on tv less than 1volt indicated at 15v is this the problem
    suggestions greatfully rec'd or is the solution to ignore the module
    salut t
  • 12-03-2008 6:08 PM In reply to
    Its likely to be an analogue sat receiver ... not sure if there are any remaining analogue broadcasts ... but you might be lucky.
    Neil
  • 12-03-2008 6:24 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    There are some analogue broadcasts, but certainly not from the Astra/Sky Satellite, they are all digital. Not possible to pick these up with Beosat LM.
    Poor me, never win owt!
  • 12-04-2008 4:56 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Hi andy
    thanks for that - in fact i have been stumbling around the website tonight and came across lots of stuff didn't know was there, hence, little contribution to the wed frolics!
    In fact discovered the analogue nomenclature also - it might work on astra 1 in france they still use analoge but for how long c'est le question!
    Back to the drawing board of working out how to contect the sat decoder to the set and how to call it up - us monkeys take a little time to catch on to new finger movements - however soon cracked the thumb sucking and nose picking ones!
    Salut a la sunny Worcestershire
    T  o  n  y
  • 12-04-2008 2:21 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Neil made the discovery last night ferreting around the beoworld site - may get it to work in France they still have analogue satellite transmission - they are a little slower than the uk in capitalizing on tv bandwidth sales!
    mx now ok got hold of an early manual from peter which has now sorted most of the problem areas - so thanks for the offer of an ir piece i don't think its needed
    salut
    t
