Latest post 11-30-2008 2:13 PM by stotty1111. 2 replies.
Page 1 of 1 (3 items)
  • 11-30-2008 1:49 PM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Remote operation problem with bs overture
    hi all
    bs overture will not respond to to remote commands (boith beo4 and beolink1000) - both remotes control other b&o stuff quite happily - the problem i think is in the overture which will happily work on manual manipulation
    looking for suggestions or is it the service depot?
    tonyConfused
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 11-30-2008 2:01 PM In reply to
    Re: Remote operation problem with bs overture
    You may be in option 0
    Try resetting to option1
    Easiest with BL1000. From STBY press SOUND, 1,STORE
    Red light on Ouverture should blink to confirm acceptance. Remotes should now work
    Regards Graham
  • 11-30-2008 2:13 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    brilliant, spot on kidder!!Party!!!Party!!!
    Thanks Graham you're a star!
    Now i'll read the handbook!
    sal;ut a nth worcs
    tony
