Latest post 12-13-2008 7:00 PM by Xseries. 2 replies.
Page 1 of 1 (3 items)
  • 11-25-2008 8:47 AM
    • twadle
    • Not Ranked
    • Joined on 04-16-2007
    • Berkshire, UK
    • Posts 15
    Speakerlink 3 to 2
    I have, eventually got around to using my Penta 1's. I have made the stupid mistake of using Powertlink 3 cables to the RCA converter cables.
    Can I modify from Speakerlink 2 to 3? and if so, could someone please explain the connections in, " colour wire" terms! (I can use a soldering iron).
    All help graciously recieved.
    Thanks, Phil
  • 11-25-2008 8:48 AM In reply to
    • twadle
    • Not Ranked
    • Berkshire, UK
    • Posts 15
    Re: Speakerlink 3 to 2
    Sorry, I mean 3 to 2.
    thanks.
    Thanks, Phil
  • 12-13-2008 7:00 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Hampshire
    • Posts 433
    I do not think that you can.  There are more wires within the Powerlink 2 than the 3 (see the technical section from where the following diagrams are taken).
    Type 2
    brownleft audio signal
    greenright audio signal
    shield: brown/greenleft/right ground
    greyon/off
    yellowon/off
    pinkAPHC
    whitedata
    shield: whitedata ground
    Type 3
    PowerLink cable without wire for display data
    Brian
