Latest post 11-24-2008 11:15 PM by beobuff. 1 replies.
Page 1 of 1 (2 items)
  • 11-23-2008 10:18 PM
    Beocom 6000 can't connect to base
    Recently purchased a second hand Beocom 6000 system, consisting of a main base with a handheld and a second base with handheld. The second handheld works fine, but the main handheld asks to register it with base. When I press OK, it says "out of range"  and then "search base, wait" and it never finds the base. Also there is a blinking red light in the handheld. Since the second handheld works fine, I assume the base is ok and the problem is in the main handheld.
     Any help is appreciated.
     Javier
  • 11-24-2008 11:15 PM In reply to
    Re: Beocom 6000 can't connect to base
    classicbuff:
     Javier
    Reboot the handset having the problem by removing and then reinstalling the battery. This usually solves the problem very nicely.
