Latest post 11-24-2008 5:06 PM by PhilLondon. 2 replies.
Page 1 of 1 (3 items)
  • 11-23-2008 5:37 PM
    DVD on link room from main room
    Im sure im set up correctly, but on the link room MX4002 i cant get a picture from my kikinoko dvd from the main room.
    Everything else is ok (cd, radio, sky), but when i select DVD in the link room the screen is just blank, although it does power up and green light comes on. Infact the tv doesnt move to position when dvd is selected either. I know the RF lead is connected properly as i have the sky picture but no DVD. What am i doing wrong?
    Thanks in anticipation
    Mark.
    Never Mind The Ball-Cocks www.markmossplumbing.co.uk
    A labourer uses his hands
    A tradesman uses his hands and his head
    A craftsman uses his hands, his head and his heart
  • 11-24-2008 4:48 PM In reply to
    Re: DVD on link room from main room
    You know when you stored the frequency for SKY in channel 60... try storing that same fequency in 61, 62, all the numbers as long as the TV accepts them.
    I also know that some BV4002 with older software cannot control the main room DVD.
    As you are a member, I would recommand downloading the PCG and it will tell you...
  • 11-24-2008 5:06 PM In reply to
    Well... I asked the PCG and here is what I got:
    The ML Module of MX 4002 must have software version (S/W) 1.5 or
    higher to be able to operate the DVD in the main room, among other
    things, order no. 8343206
