Latest post 11-11-2008 6:42 AM by PhilLondon. 6 replies.
Page 1 of 1 (7 items)
  • 11-10-2008 8:39 PM
    Beocenter 2300
    Hi everyone, I had just bought a beocenter 2300 from ebay few weeks ago. Looking through the whole manual, I cant find anything related on how to switch on the timer function. Allow me to ask a silly question, does beocenter 2300 got any timer function at all, if yes, how can I switch it on??
    Thanks for helping me out if possible........^^
    Justin
  • 11-11-2008 1:51 AM In reply to
    Re: Beocenter 2300
    As far as I am aware, there is only a stop timer in the 2300 which allows you to set the radio to switch off after a variety of times. This bis activated by pressing Radio then Stop a number of times - the desired time is shown on the display. Probably not what you wanted to hear. Sorry.
  • 11-11-2008 1:59 AM In reply to
    • BeoIce
    • Top 200 Contributor
    • Joined on 03-27-2007
    • Recklinghausen, Germany
    • Posts 281
    Re: Beocenter 2300
    I'm surprised to read that BC2300 has a sleep timer, as this is excactly what I was looking for on this unit, because I often hear radio to fall asleep and nothing is more unpleasant than playing the radio the whole night long.
    I will try sleep function as soon as I got home from work Smile
    Regards
    BeoSound 9000 MK III, BeoLab 6000, BeoLab 11, BeoCenter 2300, BeoSound Century, BeoVision MX4000/MX7000 & BeoCom 4
    Samsung UE40B7090, Samsung HT-WS1G, Technisat HD8-S, Sony PS3, Logitech PS3 IR-BT-Adapter & Lintronic TT455-RT-238
  • 11-11-2008 2:06 AM In reply to
    Re: Beocenter 2300
    I also have a dim memory that if the set is two way, there may be some chance of programming. I may however be wrong here. I attach the sleep timer page.
  • 11-11-2008 3:37 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Beocenter 2300
    2 way is possible - check for 2 sensors on the lower part.
    You need a BL 7000 or BL 5000 to use it...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 11-11-2008 6:17 AM In reply to
    Re: Beocenter 2300
    Thanks a lot Peter for your help.
    Oh....but really a bit disappointing on that!  I got a timer funcion with my beocenter 9500, which I normally use it as my alarm clock. Now may be I need to switch back to my old set up, and this 2300 can go to another room may be.
    Justin
  • 11-11-2008 6:42 AM In reply to
    Re: Beocenter 2300
    On the Beocenter 2500, which is similar, the timer can only be programmed via a 2 way remote. If you have a recent Beovision then, the Beovision can be used to start the radio or CD at a certain time. p.
