Latest post 11-14-2008 7:01 PM by Medic394. 4 replies.
Page 1 of 1 (5 items)
  • 11-09-2008 6:45 AM
    Sony Blu-Ray Player
    Hi all i have a Sony Blu-Ray player BDPS300 connected to my Beocenter 6, and i would like to ask if anybody has the function buttons on the Beo 4 to operate various functions on the player. any help would be much appreciated
  • 11-09-2008 8:56 AM In reply to
    Re: Sony Blu-Ray Player
    We have the same player connected to a BV7 MKIII in the USA. I don't know if controls would be the same on a Beocenter 6, but here is what works for us.
    list  v. aux  go...... to turn on, although today it is not turning it on for some reason today.
    stop........pauses the player, also use this to turn off, have player set up so after a pause of a period of time, I think it is two hours, it is in the player settings, it turns off
    arrows and go to navigate the disc menus
    menu 1 brings up the system menu for the player
    menu 2 brings up the video format  for the player
    menu 3 brings up the audio format for the player
    menu 4 subtitles
    red  brings up the pop or main disc menu
    green  starts the dis over, although the on screen menu says it is top menu
    yellow slow forward
    blue slow  reverse
    go and arrow up skips forward chapters, may hit arrow more than once after hitting go
    go and arrow down to skip back a chapter, may hit arrow more than once after hitting go
    go and arrow left to scan backwards, hitting arrow more than once increases speed
    go and and arrow right to scan forward, hitting arrow more than once increases speed
    go twice to stop scan forward or back.
    Hope this helps.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 11-09-2008 9:11 AM In reply to
    Thank's Razlaw great help.
  • 11-09-2008 9:32 AM In reply to
    Glad to help. Regarding turning the player on, I think it only works when turning the TV on. In other words if watching TV and switching to Blu-Ray it will not turn on. Also, in order to get it to work I had to activate an HDMI control in the player's set-up menu.
  • 11-14-2008 7:01 PM In reply to
    Hi Razlaw just a quick question again which button if any do you press on the Beo 4 to open the dvd tray if any, or do you have to press the button on the sony remote.
    reagards Dave.
