Latest post 11-06-2008 5:20 AM by PhilLondon. 1 replies.
Page 1 of 1 (2 items)
  • 11-06-2008 4:57 AM
    beo4 use - A/V
    Hello,
    has anybody an idea how to switch on the audio master for an AV-connection, weh you want to have the video-sound from a DVD1 on your speakers that are connected to an audio master. I only have a beo4 with CDV-softkey. I tried almost everything to get this done - notmally you use TV - AV - TV with the "hard-keys". To switch on the DVD1, I use LIST (x-times) till CDV occurs than GO. DVD switches on. When I now press the AV button an GO (again - CDV is still on the display) - no reaction on the master. even if I press AV and LIST (again till CDV lights up on the display) an than again GO - no reaction. Any hints?
     Thanks,
    Alex.
  • 11-06-2008 5:20 AM In reply to
    Re: beo4 use - A/V
    You should press AV, then LIST until CDV is displayed, then GO.
    p.
