Latest post 05-18-2007 9:58 AM by Dillen. 2 replies.
Page 1 of 1 (3 items)
  • 05-16-2007 4:17 PM
    Beogram 6000 - not working
    Can anyone throw any light on what has gone wrong, and how I can fix my turntable; it doesn't rotate when I press the 'Start' button, although it does rotate when I hold down the 'Turn' button. Any assistance would be appreciated.
  • 05-16-2007 4:47 PM In reply to
    Re: Beogram 6000 - not working
    Sounds like a switch problem as the motor is clearly working. However Martin is the expert here!
  • 05-18-2007 9:58 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    There are two versions of the Beogram 6000, one has a radial arm, the other tangential. Since you mention a TURN key I suppose you have the radial version. It won't start (and rotate the platter) without a record on it (TURN will still work though !) If you have a record on the platter and it still won't start there is a fault somewhere.
    First thing to check would be the start button which contacts have a tendency to oxidate, try pressing it slightly harder than you would normally do, use "controlled finger-force" or repeatedly.
