Latest post 11-08-2008 6:21 PM by burantek. 16 replies.
Page 1 of 1 (17 items)
  • 11-04-2008 12:06 PM
    • RHSeymour
    • Not Ranked
    • Joined on 11-02-2008
    • Beaufort, South Carolina
    • Posts 8
    • Silver Member
    Connecting Beogram 3404 to non-B&O tuner / receiver
    Hi. Several years ago I bought a B&O system including a Beomaster 2000 series, master link, and Beogram 3404. All but the 3404 went when we sold the house. I powered up the turntable a few weeks ago, everything seems to be working and the needle looks good. I bought a TCC preamp (TC-400) to connect my turntable to a Sony tuner / receiver but I have to raise the tuner volume to its maximum to get any sound, weak and very distorted. Connections are 5 pin din to RCA to preamp, RCA from preamp to tuner. Ground wire from turntable chassis to tuner ground. I'm thinking I may have a bad preamp or (possibly) a bad cartridge Unsure. Any suggestions or advice are welcome.
    Rich
  • 11-04-2008 1:23 PM In reply to
    Re: Connecting Beogram 3404 to non-B&O tuner / receiver
    howdy fellow carolinian... welcome to beoworld!
    take a quick look here
    i used a tcc also -the 750 -though to a non riaa beomaster. worked great after fiddling.
    1.) confirm the rca's are all placed correctly!!!
    2.) does the 400 have a dial to "whick it up" like the 750?
    3.) the 750 does and i had to crank it up to come close to matching the other sources -still not equal, but ok.
    4.) your cartridge may well be bad if you still get nothing. i happen to have a 3404 and i could send the cartridge off to you for testing (we don't live that far apart).
    keep us posted.
    • B&o bottle opener
  • 11-04-2008 1:32 PM In reply to
    oh...
    and i have several bm1900/2000/2400's available if you'd like to go "back to the future."
    • B&o bottle opener
  • 11-04-2008 1:52 PM In reply to
    • RHSeymour
    • Not Ranked
    • Posts 8
    • Silver Member
    Jeff, Thanks for the fast reply. The 400 is a vanilla version with no dials to tweak so I think I'll move up to a pre-amp with better capabilities. As soon as I can get a replacement I'll let you know. RCAs are tight and look to be correctly connected. Thanks for the offer to test with your cartridge and have you a price for the BM 1900 or 2000?
    RichSmile
    Rich
  • 11-04-2008 2:05 PM In reply to
    you know what, my tcc750 + cables are not in use right now.
    i'll set it up and play w/ it tonight, and see what i come up with...
    i seem to remember the rca connections were not exactly straight forward.
    i'll have to review the bm's i have and let you know -of course, you wouldn't need the preamp then...
    • B&o bottle opener
  • 11-04-2008 6:05 PM In reply to
    rich,
    you mentioned you were sending the ground to your sony, does the 400 not have a grounding lug?
    also, is your din out to (2) rca's or (4)?
    regardless of all the above -my prob ending up being the cart -no fiddling would deal w/ that i am afraid.
    lmk the above and i think it my be best to go ahead and get a good cart to you for testing as my bet is that is what is wrong.
    send a "PM" to me if you want (using "contact -send personal message" in the top of this frame) to fwd any personal info to me...
    upon a reply from me you will see your personal inbox in the top right corner of this page will have a message...
    • B&o bottle opener
  • 11-05-2008 9:30 AM In reply to
    • RHSeymour
    • Not Ranked
    • Posts 8
    • Silver Member
    Jeff,
    The 400 doesn't have a grounding lug and my concern was making sure the TT was grounded to the amp / tuner. The din adapter has just 2 rca outputs and no ground. I'll send a pm and take you up on the offer of a test cart.
    Rich
    Rich
  • 11-05-2008 10:15 AM In reply to
    RHSeymour:
    Jeff,
    Rich
    ok, well then the 400 and the 750 are quite different, and the (2) rca would be tough to not hook up correctly -hee hee. (i was running to a 4).
    i will chk my PM's!
    ++++ rich, you have a PM ++++
    • B&o bottle opener
  • 11-05-2008 1:43 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    RHSeymour:
    Rich
    Is it wired the correct way? This is why you are better of with the type with 4 RCA connections.
    CraigSmile
  • 11-05-2008 3:01 PM In reply to
    • RHSeymour
    • Not Ranked
    • Posts 8
    • Silver Member
    Craig, I never thought to check. I picked it off E-Bay a few months ago and figured it was wired correctly.  Embarrassed
    Could you steer me to a pin-out diagram. Thanks.
    Rich
  • 11-05-2008 3:24 PM In reply to
    Craig:
    RHSeymour:
    Rich
    CraigSmile
    @ craig -indeed. as mentioned, i ran mine w/ the (4) rca -and the wiring was not that straightforward. it took a couple of re-do's to get the lines correct.
    @rich -obviously, i have the (4) lead type -and i am sure i prob have several more -i'll take a look tonight!
    • B&o bottle opener
  • 11-05-2008 3:41 PM In reply to
    • RHSeymour
    • Not Ranked
    • Posts 8
    • Silver Member
    Craig, checked and the connector is wired correctly. Guess that puts the cartridge in doubt.
    Thanks,
    Rich
    Rich
  • 11-07-2008 8:15 AM In reply to
    Rich,
    i have a 20e in my hand -i will send out this AM.
    • B&o bottle opener
  • 11-08-2008 3:52 PM In reply to
    • RHSeymour
    • Not Ranked
    • Posts 8
    • Silver Member
    Jeff, Darndest thing!! Conected TT to Sony tuner through TC-400 pre-amp, removed my cart and put in your 20E. Started TT..overloaded speakers with hum. Swapped TC-400 for TC-750L with gain control at low end. MUSIC!!.LaughingRemoved pre-amp..still music. Replaced your 20E with my 20EN..still music. Only guess is that the Sony phone input has its own pre-amp and all the while it was overloaded!
    I'll use the TC-750L output to connect the Beogram to my PC and am returning your 20E with many thanks!
    Rich
    Rich
  • 11-08-2008 4:05 PM In reply to
    • Craig
    • Posts 4,855
    Glad to hear you got it workingWink
    CraigSmile
  • 11-08-2008 4:14 PM In reply to
    • RHSeymour
    • Not Ranked
    • Posts 8
    • Silver Member
    Craig, Thanks for your tip on din to RCA cabling. try to avoid working with more than 2 pins as I usually wire them backwards. They're not in order anyway. Rich
    Rich
  • 11-08-2008 6:21 PM In reply to
    rich,
    glad to hear you are up!
    monday am quarterback: i was wondering if that sony had a pre-amp!!!
    as homer says: d'oh!!! i should have said something!!!
    at any rate, i am going thru my 1900s and 2400's today for validation.
    if you still have an interest in one (or anything else) i will be heading to savannah for turkey day...
    lmk -and congrats on your success!
    p.s. i will email you my mailing address for the 20e return.
    • B&o bottle opener
