Latest post 10-28-2008 4:59 PM by david707. 2 replies.
Page 1 of 1 (3 items)
  • 10-28-2008 1:15 PM
    Avant MK2 mute picture
    Is there a way to mute the picture (not switch the tube off) with the TV in option 1? Vsetup>go>picture>go mutes it briefly then it comes back on. This also happens in option 2. This is the annoying thing about beo4 operated B&O sets. With BL1000 it was simply picture>mute
    David
  • 10-28-2008 3:51 PM In reply to
    Re: Avant MK2 mute picture
    A picture mute function isn't available in the avant.
    An alternative is using AV-TV or AV-Vtape etc.
    Just add AV to the list in the Beo-4.
    Using AV-TV from stand-by the avant starts without using the tube.
    From TV to AV-TV, the avant swithes to a dark screen, which will switch off the tube some minutes later.
  • 10-28-2008 4:59 PM In reply to
    Yes, these functions work in option 2 which is not really suitable for my configuration. Where there is no teletext signal I find the text button is a way of achieving this (for e.g a V.aux source)
    David
