Latest post 10-31-2008 1:45 AM by pjorde. 6 replies.
Page 1 of 1 (7 items)
  • 10-28-2008 2:20 AM
    Selecting the right stand for the Beovox S45-2 speakers
     I recently purchased a nice pair of S45-2 speakers and need to buy a pair of stands for them.
     I have an opportunity to purchase a nice pair that the seller says will work with the S45 speakers but I have heard that these might not work with the S45-2's.  The product number on the speakers is 6017.
    Any advice will be appreciated.
     Pete
  • 10-28-2008 3:39 AM In reply to
    Re: Selecting the right stand for the Beovox S45-2 speakers
    That is the stand for the later model - it fits the later S45. S55 and S80. It will fit the S45-2 as the bolt holes are the correct spacing but is quite a bit taller and in my view makes them look a little strange.
  • 10-28-2008 8:36 AM In reply to
    Are you certain you have the S45-2 and not the S45? the type number on both of my pairs is 6312.
    Simon
  • 10-28-2008 8:54 AM In reply to
    The type number of the S45-2 speaker is T6312 and the stand is T6013. The later S45 is T6427 and the stand is T6017.
  • 10-28-2008 11:40 PM In reply to
    Hi Peter,
     Thanks for the response...yes, the stands are T6017 and my speakers are T6312.  Based on your previous notes, this is not the designated stand for the my speakers.  If you were me would you make these stands work or wait to find the T6013s?
     Pete
  • 10-29-2008 11:18 AM In reply to
    I think you have answered your own question, it will always bug you a little if you don't have the original stands!
    I am not sure where you are located, but on UK Ebay a set of S45-2s with original stands will often fetch less than a set of stands sold separately, so it is worth keeping an eye out and getting a spare pair of speakers into the bargain.
    Simon
    pjorde:
    Hi Peter,
     Pete
  • 10-31-2008 1:45 AM In reply to
    I have to agree.
     I'm in Southern California but I'll have to keep my eyes open for a pair here to avoid the internatiional shipping costs.
     Maybe someone who has one will see this posting and let me know.
     Thanks much for the help.
     Pete
