Latest post 10-25-2008 6:08 PM by cjocc. 5 replies.
Page 1 of 1 (6 items)
  • 10-23-2008 2:54 PM
    • cjocc
    • Not Ranked
    • Joined on 09-07-2007
    • Sweden
    • Posts 39
    Can I get my MX7000+BC2 setup to work with a HDR2?
    Hello all you bright ones!
    I have a MX7000 connected with a BC2 via a MLC. I wonder if it's possible to replace my V8000 with a HDR2? Ist it possible to get working with this setup? If so, is there any minimum SW or product serie# levels that is needed?
    Best Regards
    cjocc
    BC 2, MX7000, BeoPort, BLab 35000,BLab 3,BLab 8000,BeoC 6000, Beo4
  • 10-23-2008 4:20 PM In reply to
    Re: Can I get my MX7000+BC2 setup to work with a HDR2?
    It should work... HDR1 & 2 work like a Video recorder.
  • 10-24-2008 1:00 PM In reply to
    • cjocc
    • Not Ranked
    • Sweden
    • Posts 39
    Thanks wtlc2zpx
    But "It should work...." is not enough for me.
    Can I get a more distinct Yes/No? I have followed threds on HDR2 and Avant which hasn't worked but should work....
    Thanks in advance
    cjocc
  • 10-25-2008 6:00 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    MX8000 with SW > 2.91 is supported, older MX like 4000, 6000 and 7000 not!
    Gerd
  • 10-25-2008 8:36 AM In reply to
    You can use the DVD2 with an MX7000, but they don't sell it anymore.
  • 10-25-2008 6:08 PM In reply to
    • cjocc
    • Not Ranked
    • Sweden
    • Posts 39
    Thank you all,
    Sometimes is worth to be persistent! Pitty though that the result this time just gave me more headache how then went from a video upgrade project to upgrade my television. I guess that I will go the Beovision 4 way with the BS3, or would anyone one suggest anythin else?
    Cheers
    cjocc
