Latest post 10-19-2008 1:50 PM by Alex. 2 replies.
Page 1 of 1 (3 items)
  • 10-17-2008 8:18 AM
    iPhone - Avant connection
    Considering the expense and the clutter of connecting my Avant to Apple TV I was considering the following option:
    "Apple iPod AV Connection Kit, with Dock and Remote"
    Please can anyone tell me if this is possible
    Many thanks
    Peter G
  • 10-19-2008 9:33 AM In reply to
    Re: iPhone - Avant connection
    i am not sure at what kit you are looking at. I believe the native Apple one will not display the menu on the TV screen, just the movie, so you could only do blind navigation.
     I think the current classic ipod may not even support that, I noted that the "Touch" specs explicit note that it can output 480p but for the classic it does not.
    Did you consider just getting a mini mac? It's a bit more expensive but you also get much more (i expect it to be updated before christmas). For older mini macs you can get ATV4mac (Tiger/Intel only, not the current Leopard OS).
    Are you after the movie rentals? Or do yo just want to play your own content?
  • 10-19-2008 1:50 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    I think the best solution is going to be an Apple TV with the component > RGB adapter...
     Weekly top artists:
