Latest post 10-09-2008 6:21 AM by Adam. 4 replies.
Page 1 of 1 (5 items)
  • 10-08-2008 2:05 PM
    • Adam
    • Not Ranked
    • Joined on 10-08-2008
    • Athens
    • Posts 4
    Beocenter 1 Access Code for Picture Control Settings
    There is a code for altering the preset picture settings (colour, contrast, brightness etc.) on the Beocenter 1. Unfortunately, the notebook where I had it is lost. Does anyone have this code so that I can fine adjust the Beocenter 1 settings to my personal likings?
    Thanks.
  • 10-08-2008 5:51 PM In reply to
    Re: Beocenter 1 Access Code for Picture Control Settings
    Anyone??????
    I have not had a BC1 for 2 or 3 years and I can't remember.
    Regards Graham
  • 10-09-2008 12:49 AM In reply to
    • Adam
    • Not Ranked
    • Athens
    • Posts 4
    Do you maybe know any site where I can find this info?
  • 10-09-2008 5:37 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Select a SETUP menu.
    Beo1: Press STOP STOP GO within 3 seconds.
    Beo4: Press 0 0 GO within 3 seconds.
    Select ordinary menu operation to leave Service Mode.
    Then TV Tuner - Picture Adjustments.
    If you upgrade to become a silver member, you could download the complete service guide...I suggest you do so.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 10-09-2008 6:21 AM In reply to
    • Adam
    • Not Ranked
    • Athens
    • Posts 4
    Dear Ralf,
     Thank you very much for the tip. I will try it out.
     Best regards
    Adam
