Latest post 10-07-2008 5:52 AM by PhilLondon. 1 replies.
Page 1 of 1 (2 items)
  • 10-07-2008 4:58 AM
    Connecting BeoVision 7 32" with DVI output to HDTV signal
    Can please somebody explain me how to connect BeoVision 32" type 9311 with DVI socket to HDTV signal. Would I need DVI-HDMI adaptor as a set top box has HDMI output. Would I also need another cable to connect audio. Does somebody have any experiences with this type of BV7 MKI and HD television?
  • 10-07-2008 5:52 AM In reply to
    Re: Connecting BeoVision 7 32" with DVI output to HDTV signal
    The answer to both your questions are yes.
    Yes you need a HDMI to DVI adaptor and yes you need a separate audio cable as DVI does not carry the sound.
    I have not done that connection myself though.
    p.
