Hi there, could really do with some help!
Records are playing
on my system but the arm is trying to pull the stylus back to it's
starting place so the record sounds distorted and keeps skipping
backwards. Is this something to do with the counterweight or something?
Turning it around to 0 seems to reduce the problem somewhat
but it still gets stuck in the groove and sounds very crackly. When i
push down on the stylus end of the arm a little the crackling goes away
- too much weight at the back of the arm?
I just got the system through ebay and the previous owner assures me it
worked fine. Any advice would be greatly appreciated.
Many thanks, Dom
