Latest post 11-15-2009 2:10 AM by ghrammy. 5 replies.
Page 1 of 1 (6 items)
  • 09-26-2008 1:57 AM
    BeoLab Penta Type 6603
    I have a pair of BeoLab Penta Loudspeakers that need repair, does anyone know of a repair center near Virginia ?
  • 09-26-2008 3:25 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: BeoLab Penta Type 6603
    What is the problem with them?
    Chris.
  • 09-26-2008 12:24 PM In reply to
    One speaker will either hiss or pop and then light turns orange and ofcourse no sound. Unplugging works but its getting alot worse.
  • 09-27-2008 8:43 AM In reply to
    • Medogsfat
    • Posts 4,045
    Sounds like an amplifier problem. Type 6603 are the earliset MK1's so they will be showing some age now and could do with servicing in any case.
    The amps unbolt from underneath which will allow you to use the speakers as passives while the repairs are done. I'm sorry I cannot help further with a recommended repair centre in your area but if you post in the USA section of Beoworld detailing the problem then I'm sure one of our esteemed USA members will be able to help further.
    I can move this thread into that section if you like?
    Chris.
  • 09-27-2008 2:14 PM In reply to
    Thanks Chris. And please move this to the usa forums.
  • 11-15-2009 2:10 AM In reply to
    Hello there,
    I just joined the site. i have a simple setup -beocenter9000 -beogram5000 -penta6603 mk?
    i got/Had the same problem:
    I dismantled (4 nuts n washwrers on the bottom do it all! dont loose them. lay onto a bunched towel and loosen in rotation.) and found loose/bad connections, after cleaning and reassembly it worked fine..  Then! the other did the same nd got worse fast then crapped out!. I took it to a genious and he said it was all good just a smthin small problem.   note when you re-assemble those 4 crews back finger tighten only work on rotation and wobble the base on gently as you do, then a 3/4 turn only! with pliers!
    still popped and crackled at extended low volumes!! so for some reason i tried making sure i was only set to link which helps. finally i placed the speakers very far from each - i did this only to use the very large volume of funky cable without any bunching  thinking there was feedback or something. this workd great no popping or cracklkeing if not in use the speaker/s shut down to orange but after activating and unplug-repluging there great again.
    your problem might, might?, just be bunched cables? what kind are they. do your Penta screens work?
    G
