Latest post 09-21-2008 10:13 AM by joeyboygolf. 2 replies.
Page 1 of 1 (3 items)
  • 09-21-2008 7:21 AM
    • sharif
    • Not Ranked
    • Joined on 10-05-2007
    • UK
    • Posts 21
    HOW DO YOU REMOVE THE GLAS DOORS ON A BEOSOUND 3000 (FOR CLEANING)
    I WAS HOPING SOMEONE COULD TELL ME HOW TO SAFELY REMOVE THE DOORS SO I CAN CLEAN BEHIND THEM. THANKS IN ADVANCE
    FOR EVERYTHING ELSE......THERES B&O
  • 09-21-2008 7:44 AM In reply to
    • wasti
    • Top 500 Contributor
    • Joined on 08-29-2008
    • Cracow, Poland
    • Posts 112
    • Gold Member
    Re: HOW DO YOU REMOVE THE GLAS DOORS ON A BEOSOUND 3000 (FOR CLEANING)
    It is very easy. Only five steps are needed.
    1. Open the glass doors.
    2. Plug out the cable of your BeoSound.
    3. Grip firmly one of the glass doors and unfasten firstly the bottom thumb-lock. You will hear a click.
    4. Do the same with the top thumb-lock.
    5. Repeat the two last steps with the other glass door.
    That is all. Rewind all of the steps to put the glass doors where they were. If you need more clarification just ask.
    Wasti
  • 09-21-2008 10:13 AM In reply to
    sharif:
    If you upgrade your Beoworld membership to silver or gold you could download a copy of the user and set up manual.
    Regards Graham
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
