Latest post 01-22-2009 9:31 AM by soundchoice70. 21 replies.
Page 1 of 1 (22 items)
  • 09-19-2008 9:19 AM
    BM6000 Type 2251 ....with life of its own....
    Hi All,
    This is my first post, and just want to say, great site, very informative and I throughly enjoy reading the forums.
    I have just recently joined the vintage B&O owners club, and the proud owner of a mint condition BM 6000 and S80.2 speakers all in beautiful rosewood!
    The system looks and sounds great ... however on several occasions over the last couple of weeks its been turning itself on, and yes, there is no timer set... I'm wondering what this could be ... (capacitors?) and should I be concerned.. The obvious solution would be to turn it off at the socket each day, but with this I am a little concerned that I may affect the unit with the constant on/off of power...
    Thanks in advance for your help...
  • 09-19-2008 9:32 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: BM6000 Type 2251 ....with life of its own....
    Hi and welcome to BeoworldSmile Thanks for supporting the site with your silver membership.
    capacitors can indeed cause the most bizarre fualts. Before getting too concerned it is always worth checking the simple things first. Do you have the remote control for this? If so maybe it is the remote that has a fault and is turning it on?
    I wouldn't worry about disconnecting the power, I'd rather that than the unit switch on when you aren't there and annoy the neighbours - nice system BTW, top of the range stuff in its dayWink
    I had a problem with my Beocenter 8500 turning on at all hours and it transpired that the cats were walking on the sensitouch panels in the night and switching it on.
    Chris.
  • 09-19-2008 9:53 AM In reply to
    Hi Chris,
    Thanks for the warm welcome... and for the quick response... hadn't thought about the remote being the problem, however not sure how I would test to see if this was causing it... its too sporadic to have any pattern...
    It is a good system, quite fortunate to have gotten one in such great condition, and in fact I think it produces a richer, fuller sound than the BS3000 with BL6000 we have upstairs.
    We'll have to see how it goes, I guess I'll start turing the power off to prevent any impromtu performances in my absence.....
    Thanks again...
  • 09-19-2008 10:15 AM In reply to
    @medog: i am LOL -the first thing i thought about when reading the OP -was your cats!
    i have one as well, but i have never experienced this.
    i'd say just pull the batts out of the remote, or remove the remote from the room and see what happens.
    might there be something else possibly interfering with it?
    also, anyone have any comments regarding the q about powering up and down vs. leaving on standby? i will often power down systems that stay dormant for a while. i too would be interested in anyone's thoughts on this.
    oh! and welcome to beoworld!
    • B&o bottle opener
  • 09-19-2008 11:05 AM In reply to
    • Medogsfat
    • Posts 4,045
    Hi Jeff,
             yep it's true about my cats - I was totally confused by what was turning on my beocenter at all hours until I caught one of them doing it! I ended up buying a wall mounting bracket to stop them.
    I agree re:- removing the remote to another room or taking out the batteries to see if this stops it.
    My opinion on powering items down is that I would personally try to leave equipment on standby as I have heard that capacitors don't like being left idle for too long and can degrade as a result. In the above case though powering down for short periods shouldn't cause any problems. I could be wrong though.
    I'm sure member Dillen (Martin) can offer more advice & possibly even a capacitor kit for this model.
    Chris.
  • 09-19-2008 12:20 PM In reply to
    • Mohawk
    • Top 500 Contributor
    • Joined on 01-30-2008
    • Sweden
    • Posts 103
    • Gold Member
    Hi
    If it's not the remote (nor the cats Big Smile) you might want to replace capacitors. Check the remote receiver module especially for bad caps and solders.
    /Fredrik
  • 09-19-2008 12:30 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Wow, a wall bracket for cats ?
    My cat walked on my BM8000 only once. I saw it, put my coffee cup down and was about to get up to teach it when it stepped on the volume wheel, turned a somersault and never came near it again so that problem pretty much solved itself.
    Yes, a capacitor kit is available and recommended but in this case I would try to look for cracked solders at the lower connectors at the processor board and at the module 14 which is the board just below it. The last many BM6000's I've seen had lots of them.
  • 09-19-2008 2:57 PM In reply to
    • Medogsfat
    • Posts 4,045
    Dillen:
    LaughingLaughingLaughing
    Brilliant Martin - why didn't I think of that one?Confused
  • 09-19-2008 5:50 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Dillen:
    Had the cat problem with my old Beocenter 9000, I would walk into the room to find the CD or tape open. Cat's never managed to turn it on though.LaughingLaughing
    CraigSmile
  • 09-19-2008 10:19 PM In reply to
    Hi Everyone,
    Thanks for all your ideas on how to nip this problem in the bud... Will try each and see whether it solves the issue .. unfortunately its not a music loving cat!
    Failing that i will venture into unchartered territory and try opening up the unit and see if I spot any of the internal issues suggested... Have downloaded service manual , so as prepared as I can be! Any tips would be appreciated, will have to also search on the forums again as I'm sure there is a thread somewhere on the caps replacement.
    Dillen perhaps you could let me know how much your kits for caps for both the BM and speakers are? So if I need to go this route I can order from you.
    To all, have a great weekend ahead!
  • 09-20-2008 4:18 AM In reply to
    • Dillen
    • Posts 5,008
    You have a PM !
    (Check your inbox at the upper right corner).
  • 09-25-2008 4:28 PM In reply to
    Common problem with this unit,but a simple mod should sort it if none of the above remedies suffice.Soldering required,but only one component.
  • 09-26-2008 9:14 AM In reply to
    Hi All,
    Just an update, the turning on became increasingly frequent (almost daily) last week and has stopped this week... so who knows.. just decided and have ordered my caps from martin and once they arrive and are installed will let you all know how it goes... decided also since I was refurbishing things that i would also change the caps in the speakers, hoping for the same success you all have had!
    Solderon whats the 'mod' required that you are refering to? Is it the caps replacement?
    Thanks.
  • 09-26-2008 9:37 AM In reply to
    • Dillen
    • Posts 5,008
    Oh yes, I think he is referring to a resistor modification in the
    remote control receiver. This was an issue on the very earliest Beomasters
    of this type.
    Funny if it hasn't surfaced earlier in your Beomaster but I suppose
    it's possible.
    I can include the resistor and instructions with the kits.
  • 09-26-2008 7:25 PM In reply to
    Hi Martin,
    Ok thanks for the clarification, yes please include the resistor and instructions with the caps if thats ok, if all else fails we'll look into that problem.
    A great weekend to all...
  • 09-27-2008 12:25 PM In reply to
    Indeed yes,but problematic with later units too I've found.It might be prudent to replace the ir receiver diode while you are at it,as this can become noisy and cause all sorts of odd "hauntings"
  • 09-28-2008 12:25 AM In reply to
    Hi Solderon,
    Thanks for your advice, will add it to the list of things to check and change. Yes is quite odd, as i mentioned earlier, it started to occur and became almost daily and now has completely stopped.
    Have a good day.
  • 09-28-2008 9:56 AM In reply to
    • Dillen
    • Posts 5,008
    You can disconnect the remote option board to isolate the fault.
  • 11-05-2008 9:22 PM In reply to
    Hey,
    Just a bit of an update and a couple of questions which I thought I would share with everyone as others may have similar issues they need to  resolve.
    Have been monitoring the 'haunting' (thanks Solderon) of this unit, and as its been quite sporadic and hasn't posed any real issue, I delayed doing anything till I go away in a few weeks time.Plan to get the whole unit serviced, inclusive thanks to Martin changing all the caps, resistor required.
    I have noted the following small niggles which I would like to also resolve while its there.
    1. The volume control has the typical issue of struggling, over 30 it gets a little stuck but continues to move and is a little noisey when you adjust it with no output. Will the  simple cleaning and lubrication mentioned in other threads fix this?
    2. While testing the volume control last night I had put it to TP1 while TP2  was still receiving signal from the TV... when I put the volume up to around 40 - 50 range,  I could hear the TV signal, it was not clear or loud but obvious. When I put to PH I got what appeared more like 'back ground' noise.. Is this 'leakage' between inputs normal? or is it a result of a failure in contact/solder/cap that can be fixed?
    3. When the unit is switched off, I get what I can only describe as 'leakage' of power into the LEDs  (and mainly the clock and half the input section) making them partially glow. Bad connections / cracked solders?
    Thanks in advance for any help and will let you all know how the service goes.
  • 11-06-2008 5:23 PM In reply to
    • Dillen
    • Posts 5,008
    Forgive me for answering very briefly, I'm currently travelling.
    1. Standard issue. Cleaning and lubricating, Maybe a new belt.
    2. Open inputs will always be very sensitive (due to high impedances). It's not uncommon to see that if you switch to an unused input and turn up the volume (amplification), you can hear what's present on other inputs. I wouldn't worry too much about this,
    3. Probably just cracked solders at the connectors to the board at the bottom of the Beomaster, just below the processor board, I believe it's module 14 and their respective connectors on the processor board.
  • 11-06-2008 9:22 PM In reply to
    Hi Martin,
    Thanks for taking the time to answer its appreciated as I know its not easy when travelling.
    As usual you understand the exact problem. Well,  now I think that I have all the info I need to take the unit and be able to brief the guy at the service centre so that it gets a really good tune up!
    Thank you again.
  • 01-22-2009 9:31 AM In reply to
    Re: BM6000 Type 2251 ....with life of its own.... Back at last!
    Hi All,
    Just thought that I would make my first post on the new forum an update with some good news!
    Got my BM6000 back finally this week after nearly 9 weeks and quite some frustration.
    But the result is all good I have to report.... now despite a short panic caused by a loose contact on my airport which caused staticy, distorted sound in only one channel... the tune up was really worth the effort.
    I think that after changing the caps (thanks again martin) and the tune up that the sound feels more effortless ... could this be the case? ..... Now of course this could also be attributed to me being glad its back and also to the fact that while the unit was away, I ripped all my CDs in lossless and now stream using airtunes. This means my input is now far better quality than either via Ipod or the CD from the DVD player thru the TV ....
    So all in all am very happy ...
    Laurence
