Latest post 09-21-2008 2:35 PM by harrykym. 6 replies.
Page 1 of 1 (7 items)
  • 09-17-2008 10:34 AM
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Com 6000 base reset
    Hi all,
        Is it possible to reset the MK1 base with the built in PSTN?
         Jonnie
  • 09-17-2008 11:54 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Com 6000 base reset
    Hello jonnie
    There are two reset codes for the BeoCom6000 handset Mark 1.
    DOT 70008 will reset the base to factory setting
    DOT 70009 will reset the handset to factory setting.
    (DOT is the button between the A & V keys to the left of the wheel).
    Regards
    Opman
  • 09-17-2008 12:25 PM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Thanks Opman sorted it.
       Jonnie
  • 09-19-2008 2:48 PM In reply to
    • harrykym
    • Top 500 Contributor
    • Joined on 08-04-2008
    • Rossendale
    • Posts 86
    what's the reset for a MK II?  and will this delet all the numbers stored on the phone?
    BS-3, BS-1, BS-OVERTURE, AVANT-28"RF, AVANT-28" DVD, AVANT 32" RF, 3xBEO-4, LC-1, 4xBEOCOM-6000, BEOCOM-2, A9 KEYRING, DVD1, Beosystem 10, BEOCOM 3, BEOLAB 2500, BEOSOUND CENTURY, BEOLIT 707
  • 09-20-2008 7:22 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Think it is INT 70009 this totally resets the handset deleting numbers. The numbers stay in the PSTN though.
      Jonnie
  • 09-20-2008 7:34 PM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    9 # 9 # 9 *  INT
    Will get you into the service menu. From here you can reset the PSTN base which will wipe all information from the base or you can reset just the handset. A handset reset will all data in the PSTN intact.
    Opman
  • 09-21-2008 2:35 PM In reply to
    • harrykym
    • Rossendale
    • Posts 86
    this does not work! help?
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
