Latest post 09-22-2008 2:51 PM by snowy. 2 replies.
Page 1 of 1 (3 items)
  • 09-16-2008 2:21 PM
    • snowy
    • Not Ranked
    • Joined on 09-16-2008
    • Posts 2
    beo 610
    I have BEO610, purchased from radio rally Sunday last, The power supply, a bolt on item, was faulty, it used the 60's semiconductor tech, the OC series transistors were faulty, the radio required -(minus) 9 and 12volts, i rebuilt psu with 79** series voltage regulators, i also had to replace all the electrolytic caps in the audio section,i am listening to it as i type, my question concerning the case, the case that is with this radio has imitation leather stuck to the left hand end cheek and a small piece over the front, this is not in keeping with B&O quality, any advice as to what should be there please.Thanks, Snowy
    Filed under:
  • 09-16-2008 3:04 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: beo 610
    Hi and welcome to Beoworld !
    The BEO 610 is a strange beast but it sounds like yours is pretty much original. It should look like this:
  • 09-22-2008 2:51 PM In reply to
    • snowy
    • Not Ranked
    • Posts 2
    Re: beo 610
    Thanks Martin, it looks very nice (and sounds the same),Shame that i cant get it original, i would need the small knobs on the front as well, the grub screws are seized solid,wd40 or 3 in 1 light oil soaking hasn't helped either.
    Regards,
    Snowy
