Ivor:
The CD mechanism in the Overture manual is for a CDM 4. You likely have the CDM 12 (linear pick up) which is the updated mechanism.
( If someone has updated copy of the Overture manual, could you please upload it to the server? )
The laser current adjustment is made on the optical pick up. It is factory set for the optical pick up. There is no need to match it with the servo board.
I don't think the current level adjustment procedure applies to the CDM 12.
Derek
