I am adding a second Beoport to my set up and would like to verify what option setting I will need and re-cabling of the speaker cables.
My current setup
AvantDVD room 1
Beosond 3000 room 2
Existing Beoport room 3
(I have other ML rooms but don’t believe their info is required let me know if you need complete setup)
What I am doing
AvantDVD room 1 (no change)
Beosound 3000 room 2 adding the second Beoport
Existing Beoport room 3 (no change)
In room 2
I have the beoport and BS3000 connected to the masterlink cabling.
My speaker are currently connected to the BS3000. Will I have to connect the speakers to the Beoport?
Option setting, will they have to be like this?
Beosound 3000 – option 0 (no IR reception)
Beoport – 6 (one IR receiver in the link room)  in which case I will have to purchase the eye/ir receiver as I didn’t think I would need one.
I have set the Beoport in room to as Main PC = No
In this case how do I listen to what is being played from the main PC (e.g. N.Music) all over the house from room 2?
Thanks for your help
									    BV10, AvantDVD, BS3000, BL8000, BL6000, BL4000, BL3500, BeoPorts, BC9300, BC7002, CX100s, C75s, Beo4s, BC6000s, LC2s, A9, A8s,
