Latest post 09-10-2008 2:58 PM by rosteu. 2 replies.
Page 1 of 1 (3 items)
  • 09-10-2008 2:32 PM
    another dead mx4000...
    hello
    I read an inspiring post about a dead mx4000 with a happy ending (http://forum.beoworld.org/forums/thread/91170.aspx)
    and thought that I should have a go at a similar machine with a similar problem. Its a mx4000 beo4 and it says "type:78/34 EDT" at the back.
    symptoms are: no respons when connected to the mains - no standby light, no humming sound or anything like it.
    i measured 230V AC over P20-1 and P20-2 when connected - so its not a broken power cord :) - but 0V over C9 (supposed to be 300) and 0V between pin 1 and 6 on T6
     if you have any clue or general tip - please respond!
    many thanks
    arvid
    ps this might be a newbie question - while disconnected from mains I measured resistance between the C and E pin of TR33 (since it was the solution to the problem in the post I referred to) and got something like 600kOhm. A high resistance, but still not totally separated - would this mean that TR33 is broken?
  • 09-10-2008 2:52 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: another dead mx4000...
    Welcome to Beoworld Arvid.
    I think you might get a better response to this, if you posted it on the workbench forum.
    Good luck anyway.
    Andy T.
    Poor me, never win owt!
  • 09-10-2008 2:58 PM In reply to
    I will, thanks for the tip!
