Latest post 08-27-2008 4:14 PM by Alex. 2 replies.
Page 1 of 1 (3 items)
  • 08-27-2008 2:15 PM
    • petja
    • Not Ranked
    • Joined on 06-15-2007
    • Posts 17
    BeoLab 5 speaker problem.
    Hi guys, can anybody help me.  one of my BeoLab 5s just stopped to work.  no light flashing nothing.  i thought there has to be a fuse protector built in to protect  the speaker from fuse shortening or something what could protect the unit from voltage jumps on electricity  line.
    can anybody advice me, what could happened with speaker.  it was just ok and next moment it disappeared without any reason.  there was no sound by the time, when it has gone at all.  i just switched the system on and all the speakers were there , left the room for a few minutes, came back and one speaker gone.
    please help,
    thank you ,
    Vladimir
    Filed under: , ,
  • 08-27-2008 2:27 PM In reply to
    Re: BeoLab 5 speaker problem.
    The only thing you could do is to call your dealerSad
  • 08-27-2008 4:14 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Try changing the fuse in the plug if you have access to it. Otherwise, you'll need to call your dealer...
     Weekly top artists:
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
