You have the same fault on three decks ?
Do you have the correct transformer module according to your mains frequency ?
Beogram 6006 / 8000 / 8002 won't work with just a voltage converter as their
function depends greatly on the mains frequency and there are different transformers to suit 50 and 60Hz respectively.
