Latest post 08-22-2008 6:54 PM by skicop. 4 replies.
Page 1 of 1 (5 items)
  • 08-21-2008 5:24 PM
    • skicop
    • Not Ranked
    • Joined on 08-21-2008
    • Posts 3
    Beomaster 2000 .... type 2913 Speaker Problems
    I inherited a Beomaster 2000 type 2913 from a relative. I discovered that one of the speaker channels sounds muted at maybe half the volume of the other channel. After switching right and left speakers, replacing speaker jacks and wires, I believe one of the speaker outputs is bad. Is this something that is worth fixing? Will it be costly? Can it be done at home?
  • 08-21-2008 6:52 PM In reply to
    Re: Beomaster 2000 .... type 2913 Speaker Problems
    Very nice receiver and certainly will be repairable. If you are skilled, the service manual is available on site for silver and gold members. If not, you need a local repairer. Where are you based?
  • 08-22-2008 1:20 PM In reply to
    • skicop
    • Not Ranked
    • Posts 3
    I live in the Chicago, Illinois area.
  • 08-22-2008 2:12 PM In reply to
    Tricky! Much easier in Europe! Should have read the forum! However any repairer of electronics should be able to help. The manual is on site and has all one needs to identify which components you need. This age of equipment has the advantage of being made at component level.
  • 08-22-2008 6:54 PM In reply to
    • skicop
    • Not Ranked
    • Posts 3
    Thank you!
