Latest post 08-24-2008 1:14 AM by brendon. 5 replies.
Page 1 of 1 (6 items)
  • 08-16-2008 1:14 PM
    Apple TV - Fast Scrolling Stopped working
    Has any noticed the fast scrolling not working on the Apple TV when using the Beo4 remote?  I loaded the latest firmware version of the Apple TV but I not 100% if that why its not working now.  I have it connect to a BeoSystem 3.
  • 08-16-2008 10:49 PM In reply to
    Re: Apple TV - Fast Scrolling Stopped working
    I have the latest ATV version as well, with BV8 though. Maybe you paired the Apple remote by accident? I had no issues after the upgrade.
     Cheers
    JK
  • 08-21-2008 4:27 PM In reply to
    JK
    Can I unpair it? if so how?
  • 08-21-2008 9:28 PM In reply to
    It would be on your Apple TV under settings - general - remotes ...
  • 08-22-2008 1:36 AM In reply to
    Unpairing Apple TV with a Remote If you lose the Apple Remote that you paired with Apple TV, you can use any Apple Remote to unpair Apple TV from the lost remote by pressing and holding MNEU and << for 6 seconds. You can also follow these steps. To unpair Apple TV from a previously paired remote: 1Choose Settings from the Apple TV main menu. 2Choose Unpair Remote. When you’ve successfully unpaired the lost remote, Apple TV displays a broken chainlink ( ) symbol above an image of a remote. You can now pair Apple TV with a new Apple Remote. Pairing Apple TV with a Remote The Apple Remote works with the built-in IR receiver on Apple TV. You can set Apple TV to work only with the included remote by pairing Apple TV and the remote. To pair Apple TV with the included remote: 1Choose Settings from the Apple TV main menu. 2Choose Pair Remote Control. You can also press and hold » and ‘ for 6 seconds to pair Apple TV and the remote.
    Filed under:
  • 08-24-2008 1:14 AM In reply to
    Thank you both for the info.
