Long time lurker: First time post!!
I just purchased a master link cable to join up my Avant 32 (VCR) and Beosound Overture. I purchased these 2nd hand some time ago, but the master link cabling had been cut and I had them set up in separate rooms until now.
4 powerlink speakers are plugged directly into the telly and function well, providing surround sound with appropriate DVD and television sources.
I had hoped to use the overture as an audio source, with the sound being routed to the speakers via the telly.
I've followed the directions for pre-programming the equipment from the user manuals: the avant is "option 2" and the overture "option 0". the two are connected by a 5m masterlink cable.
However, nothing happens in response to commands for CD, RADIO or A-TAPE. the overture does not respond, nor does the avant. starting something playing on the overture does not result in any audio coming from the tv.
Am I missing something? any help would be much appreciated!
MARK
