Latest post 08-08-2008 10:54 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 08-07-2008 5:57 PM
    beocenter 2800 &1800
    Hi, can anyone help me. I have a Beocenter 2800 and a 1800, both have the same problem. when the mono button is pressed both speakers work fine, when released only one channel works properly, the other is very quiet. I believe it could be the caps (the small red ones?)
  • 08-07-2008 6:08 PM In reply to
    Re: beocenter 2800 &1800
    Is it the same with all sources? If so, it is an amplifier problem. Could be the capacitors or maybe the output transistors. You need to do some testing! I note the service manual for the 1800 is not on site - I will remedy this this weekend.
  • 08-07-2008 6:09 PM In reply to
    thanks
  • 08-08-2008 10:54 AM In reply to
    As promised, manual now scanned and uploaded.
