1st March February 2012
Latest post 07-25-2008 4:05 AM by Ben. 16 replies.
07-17-2008 6:55 AM
bambam
- Joined on 01-09-2008
- Posts 30
Hi I want to make up some cables for some B&O S55's that I have and thought I'd see what gauge/type of cable is recommended? I already have the plugs so just need the cable. Most of the B&O cables that I've seen in the past have been relatively thin (compared to some of the other stuff available). Any recommendations? Cheers
ChrDH
- Joined on 04-16-2007
- Denmark
- Posts 493
You can't use too thick a cable as you have to be able to fit it into the terminals of the din-plug in booth ends (like these: http://www.av-connection.dk/?PGr=375&ML=370). Regarding the specific cable, you can use what ever you like, do not spend a lot of money on cables for the S55, it probably worn't make a difference anyway. A cable like this would do: http://www.av-connection.dk/?PNo=SP2-075&ML=359 but you might prefer it in white or black. br Christian
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
wirralsimon
- Joined on 04-17-2007
- Birkenhead, UK
- Posts 1,253
There is a lot on nonsense spoken about speaker cables in the Audiophile community and you can end up paying a fortune. A relatively inexpensive medium thickness OFC cable should be more than adequate for the job, you should pay no more than a couple of euros a metre at most. Simon
Graham1982
- Joined on 11-22-2007
- Cambridge, England
- Posts 531
Yeah, what is all this cack I have heard about cross-wiring speaker cables and stuff like that. I use relatively thick speaker cables but I buy online then you don't get all the nonsense from sales staff that in the main don't know what they are talking about. The worst example of similar rip-off behaviour I have heard of was when I was working in Curry's as a student. DVD players had just started getting cheap - like £20 or so and this little old granny had bought one. For an add on sale, the salesman sold her one of those oxygen free, gold plated nonsense scart cables for £70. In the end I just gave her a scart from one of the display models.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
ChrDH: You can't use too thick a cable as you have to be able to fit it into the terminals of the din-plug in booth ends
Very true, I once tried to replace the wire on some S30's with some 2.5mm cable. That was about as big as I could go with the speaker connectors. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Alex: Puncher: Alex: You can tell the difference between a good and bad cable by it's 'rubberyness'. Good cables generally feel soft and rubbery, whilst a bad quality cheap cable feels like plastic.
   What? All the XLRs/Jacks I've bought which feel cheap 'n plasticy fail within months, wheras I've got some good quality jacks which go back 30 years when my dad bought his guitar.
They'll be plugs then - I thought you where talking about cable. The cable to which you infer will likely have an EPDM (rubber) sheath. This gives the cable the properties of abrasion resistance, flexibility, long flex life and general all round ruggedness. Just the job for a guitar or mic lead that is continually scraped along the floor, bent at all angles and then wrapped up again at the end of the night. You may, by now, have noted none of these properties are high up on the list of requirements for speaker cables. Plain old PVC insulation will do perfectly well for speaker interconnects. As has been mentioned earlier a reasonable cross sectional area is by far the most important requirement.
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Green coloured cables will a clearer, sharper and more rounded sound than inferior, mauve cables. Red cables give a really quick sound whereas orange cables tend to be a bit tangy. All this must be true, it's on the internet. Andy T.
Craig
- Posts 4,855
Jandyt: Green coloured cables will a clearer, sharper and more rounded sound than inferior, mauve cables. Red cables give a really quick sound whereas orange cables tend to be a bit tangy. All this must be true, it's on the internet. Andy T.
Andy have you been on the Holsten again?    Craig
Alex
- Bath & Cardiff, UK
- Posts 2,990
Jandyt:Green coloured cables will a clearer, sharper and more rounded sound than inferior, mauve cables. Red cables give a really quick sound whereas orange cables tend to be a bit tangy. All this must be true, it's on the internet. Andy T.
Okay okay, I'm not trying to say that some speaker cables will sound better than others because of the way they feel or look (the only difference you'll find from what I can tell is related to the resistance of the cable, and the difference is still negligible), but a good cable will last longer.
Weekly top artists:
Puncher
- Posts 9,588
Alex: Jandyt: Green coloured cables will a clearer, sharper and more rounded sound than inferior, mauve cables. Red cables give a really quick sound whereas orange cables tend to be a bit tangy. All this must be true, it's on the internet. Andy T. Okay okay, I'm not trying to say that some speaker cables will sound better than others because of the way they feel or look (the only difference you'll find from what I can tell is related to the resistance of the cable, and the difference is still negligible), but a good cable will last longer.
Good lad - you know it makes sense  I would say that normal, PVC insulated wire of 1.0 - 1.5 mm2 CSA is OK for almost all B&O amps & passive speakers. (I include the "almost" in case there are some I haven't remembered). Bear in mind 1.0mm2 wire is approx. 0.019 Ohms per metre and 1.5mm2 is ~ 0.013 Ohms per meter (x2 as it is a twin cable). Compare this to your 4 or 8 Ohm speakers (this is a first order approximation). For longer runs use bigger cable - simple! I'll leave their relative frequency response for audiophile mags to discuss As a "sanity check" look up the B&O supplied cables for their best/most powerful passive speakers and ask yourself "why would they sell undersized cables for speakers that cost that much if a simple increase in cable spec/size made the speakers sound better).
bambam
- Posts 30
Very helpful - thanks very much. I just wanted to be sure there wasn't something specific that I should go for - common sense told me there wasn't, but always worth checking!
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
hi all just to add some info - i used cable from maplin (uk supposed electronics shop - now toys etc) with great effect on various speaker systems -n a cleaner crisper sound to my jaded ears - details Oxygen free(i think) by Eagle label details - Speaker cable - High quality - 2 core - extra flexible - flat profile - 1.0mmx2 x 126/0.1mm ref E635 this cable when used with maplin screw terminaled speaker din plugs works for me especially with the ease of plug connection! hope this is of use - haven't had time to check maplin.co.uk website but suspect it is still available salut a la france tony s
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Ben
- Joined on 12-28-2007
- Taunton, UK
- Posts 131
After reading http://www.roger-russell.com/wire/wire.htm I have abandoned buying thick, impressive looking cable, and an now back to using 'basic' 14/16 gauge cable! Have a search for the Philips 16 Gauge on google, its nice quality, and is reasonably priced. Although I have used 1 or 1.5mm2 2 core flex for installations where the wire is hidden.
Page 1 of 1 (17 items)
