Latest post 07-12-2008 6:12 AM by dylan. 2 replies.
Page 1 of 1 (3 items)
  • 07-11-2008 8:41 PM
    • dylan
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Perth, Australia
    • Posts 117
    Error reading setup initialization file
    I'm trying to setup the Beo5CTSetup_1.30.exe config tool on my PC and I get the above error message as soon as I try to run it. The file is 68372kb and comes from a reliable source and I have tried downloading it afresh a couple of times. I've turned off my Zonealarm and AVG antivirus which makes no difference. Have also tried removing all previous config versions. Have upgraded from XP SP2 to SP3 still no joy. Happens on both my main PC and my laptop.
    Any ideas?
     Dylan
    BS3200 BV7 BV3 BL8000 BG4000 BL4500 PC2 BG5500 MX4002
  • 07-12-2008 5:33 AM In reply to
    Re: Error reading setup initialization file
    Filesize is wrong.
    12-07-2008  11:50    <DIR>          .
    12-07-2008  11:50    <DIR>          ..
    16-06-2008  14:43        70.112.689 Beo5CTSetup_1.30.exe
  • 07-12-2008 6:12 AM In reply to
    • dylan
    • Perth, Australia
    • Posts 117
    Thanks Piet - I'll try and get another copy - suspected it must be something to do with the file as same problem on both my computers.
    Dylan
