Latest post 08-05-2008 1:49 AM by joeyboygolf. 7 replies.
Page 1 of 1 (8 items)
  • 07-06-2008 4:24 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Centre panel for a bc 8500
    hi all
    anyone out there got or can point me at a centre panel for a bc 8500 - mine got damaged last week by a halogen lamp being upended by a curtain movement caused by high winds thro' the patio door! - it chipped the dark grey paintwork - about a 10mm chip - really fortunate not to have crashed onto the glass panel!
    salut
    tony s
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 07-06-2008 4:55 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Centre panel for a bc 8500
    As fas as I know only the panels for the Beocenter 9300 are still available from B&O.
    CraigSmile
  • 07-06-2008 5:50 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    ta for that but are they in shiny/brushed ali/steel or can i get one in matt grey?
    t
  • 07-06-2008 6:47 AM In reply to
    • Craig
    • Posts 4,855
    They are as you say the Brushed Alluminium ones. not sure how you can get hold of the painted ones for the Beocenter 8500.
    CraigSmile
    • Craig
    • Posts 4,855
    CraigSmile
  • 07-06-2008 9:22 AM In reply to
    Only 9300 shiney panels available new.
    You are probably best off buying a set of 3 grey panels if you can find them, as panels all fade based on the light in the room they have been stored. So a centre panel from somebody else is unlikely to match your cd and tape panels.
    Regards Brett
  • 08-04-2008 4:42 PM In reply to
    Does anyone know how much these new shiny panels would cost and how can you order them from b&o? I dont have a b&o dealer in the near region. Just asking if worst comes to worst
  • 08-05-2008 1:49 AM In reply to
    The set of polished panels costs around £100 and is available from B&O.
    Regards Graham
