Latest post 07-01-2008 10:02 AM by Opman. 1 replies.
Page 1 of 1 (2 items)
  • 07-01-2008 8:41 AM
    Lip sync problem or re-writing physics!?
    Downstairs I have an AV9000 TV with the MPAV, connected to a pair of Beolab Pentas and a pair of Beolab 4500's.  BBC 24 comes via a digital/analogue box and the sound and picture match perfectly.  However, upstairs, I have a Beovison 6-22 connected to a pair of Beolab 4000's and Ouverture, using an identical digital/analogue box as downstairs but the sound arrives before the picture!  The lip sync is out by at least ½ a second and looks like everyone is miming!  I assume there is some set-up problem that I can't think about rather than I've re-written all of the physics books by making sound travel faster than light!
    Anybody got any suggestions as to what the problem is as it's driving me mad.
    Many thanks.
    Dave.
    Am I ready? I was born ready!
  • 07-01-2008 10:02 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Lip sync problem or re-writing physics!?
    Hi Dave
    I came across this problem a few years ago in a showroom.  Sky digital was playing through a plasma in the home demonstration room. The audio from the Sky broadcast was also playing in the showroom through a BeoLab3500. If you stood in the doorway to the home dem room you could hear that the audio in from the Lab3500 was out of synch with the sound coming from the speakers connected to the BeoSystem2.
    I rang B&O Technical and they told me that the software in the Plasma (BeoSystem2) was delaying the audio signal a fraction to allow it to synch with the video signal being displayed on the plasma. In the service menu you could adjust the delay to make the audio in synch with the BeoLab3500 but obviuosly you would end up with the situation that you are in now i.e the lips being out of synch with the sound.
    Whilst I understand the cause of the problem I think you need somebody more technical than me to explain how to correct it. I'm sure it will be an easy fix once you get into the service menu.
    Good luck.
    Opman
