Latest post 07-01-2008 2:36 PM by joafog. 7 replies.
Page 1 of 1 (8 items)
  • 07-01-2008 8:26 AM
    • joafog
    • Not Ranked
    • Joined on 07-01-2008
    • Posts 4
    Beo5 change
    I would like to change the configuration of my Beo5, but where can I find the software (Beo5 Config Tool)? Do I need to take the remote to my dealer?
    //Joacim
  • 07-01-2008 9:05 AM In reply to
    Re: Beo5 change
    The official answer to this is yes - you need to see your dealer. They have been told not to distribute the software.
  • 07-01-2008 9:44 AM In reply to
    Re: Beo5 change
    Although unofficially you could probably find a torrent.
  • 07-01-2008 1:08 PM In reply to
    • joafog
    • Not Ranked
    • Posts 4
    Re: Beo5 change
    I have tried to search intenet but without success! Anyone who know where?
  • 07-01-2008 1:17 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Beo5 change
    Even if you get the software, you need to be connected to the server to get the last firmware. You need Username and Password what only the dealers have.
    Quim
  • 07-01-2008 2:23 PM In reply to
    • joafog
    • Not Ranked
    • Posts 4
    Re: Beo5 change
    So I cannot konfigure more zones and applications like DVD, CD etc. without having access to this server?
  • 07-01-2008 2:27 PM In reply to
    Re: Beo5 change
    You can but I suggest you get the dealer to upgrade the firmware first. Once you have done that, you can, if you can find it, use the software to change whatever you want.
  • 07-01-2008 2:36 PM In reply to
    • joafog
    • Not Ranked
    • Posts 4
    Re: Beo5 change
    I got my Beo5 yesterday from the dealer and it is configured but not the way I wanted, that is why I need the software so I can configure the Beo5 as I I want!
