Found time today to check the tweeter.  It measures 14 ohms.  This was my first time using a multimeter, I had the dial set to 200 ohms, and then used the black and red prongs.
 So I am guessing that that reading is normal?  I proceeded to open the speaker up for a look see. Everything seems pretty clean and normal, except what I think is the transformer (ovoid wrapped with copper strands and shiney plastic?) has a few amber blobs under the shiney plastic.  Normal?
 Also, when I have the working 2500 hooked up the the MX 5000 and "insrtuct" the tv to use powerlink, the little green light turns on.  But once I have turned off the tv, the light never returns to red?
Guy
