Latest post 06-19-2008 8:30 PM by dylan. 7 replies.
Page 1 of 1 (8 items)
  • 06-17-2008 12:58 AM
    • dylan
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Perth, Australia
    • Posts 117
    Mac mini & remote Buddy
    I'm considering buying a Mac mini to act as a media server and allow for using a iPhone/iTouch as a remote control using Remote Buddy.
    A couple of questions:
    1) Is the mac route the only way to go to get the ability of a "two way" remote for browsing through music files etc - pretty sure it is but just wanted to be sure as have never had a mac and would prefer to just use my PC if was possible.
    2) As mac mini has inbuilt bluetooth is there any reason I need an Airport Express as well? I will be sending the music through beoport to link rooms so assume that the iPhone can just talk to the mac mini to control itunes and no need for the Airport?
    3) Is Remote Buddy still everyone's favoured solution?
    thanks in advance
    McVirgin
    BS3200 BV7 BV3 BL8000 BG4000 BL4500 PC2 BG5500 MX4002
  • 06-17-2008 2:33 AM In reply to
    Re: Mac mini & remote Buddy
    Yep, there are solutions for PC, enabling the iPod Touch to serve as a remote. One solution is Signal. It can control other applications than iTunes. E.g. Winamp
    Applications like Remote Buddy and Signal use your home WLAN to connect. As long as the MacMini is connected to your WLAN router, there is no need for Airport Express
    Its my favourite
    Regards
    Claes
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 06-17-2008 2:39 AM In reply to
    • dylan
    • Perth, Australia
    • Posts 117
    Thanks Claes very helpful - will look into Signal. Why do you prefer Remote Buddy to Signal?
    Dylan
  • 06-17-2008 2:43 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    I bought and used Remote Buddy for a few months, but have switched to Signal recently. It's more simplistic, enables you to send your music to more than one Airtunes speaker and more.
  • 06-17-2008 2:59 AM In reply to
    • dylan
    • Perth, Australia
    • Posts 117
    That's good to hear Moxxey.
    Would be interested to hear of anyone's experience of using Signal in the PC environment - sounds like this might be the best way forward for me (at least cheapest to try initially)
  • 06-18-2008 1:34 AM In reply to
    dylan:
    Dylan
    Good it helped.
    I just think Remote Buddy simply have a slightly nicer interface.
    /Claes
    _____________
  • 06-19-2008 6:18 AM In reply to
    You could also consider Salling Clicker - that operates by Bluetooth or WLAN, and gives you good interaction with your sources and programs on a Mac mini.
    I haven't used Signal - but Remote Buddy is now fully integrated with multiple room playback, in a very elegant way, and I am very happy with it. It gives you control of playback through AppleTV, all connected computers and all Airport Express units -- either as single units or with all or some playing back simultaneously.
  • 06-19-2008 8:30 PM In reply to
    • dylan
    • Perth, Australia
    • Posts 117
    Thanks, but looks like Salling Clicker not available (yet) for iPhone. Will probably start by (dare I say it now that this thread has been moved to the Mac forum Surprise ) not buying the Mac Mini and sticking with my windows-based system and trying Signal.
    Thanks for everyone's input
