Latest post 06-07-2008 12:02 PM by tIRED. 2 replies.
Page 1 of 1 (3 items)
  • 06-05-2008 5:05 PM
    • tIRED
    • Not Ranked
    • Joined on 05-27-2008
    • Posts 32
    What different BV 4-50 panels exists?
    Hello!
    I would like a source of information on the different types of plasma panels that exist (or existed) in the Beovision 4-50 range. I've understood that there are models called D7, D8, D9 and possibly even D10 (at least). Could someone post a "matrix" of information (or similar) comparing the different models (tech spec, basically). Thanks for all the great support some of you people in here supply on a daily basis!
    /tIRED (of my corrupt $100.000 setup)
    Filed under:
  • 06-06-2008 6:58 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: What different BV 4-50 panels exists?
    You can find all the info in the product section of BeoWorld. Bascially there are 3 versions: the BV4-50 mkI (EU), type no 897x (resolution 1366x768), followed by the mkII, type no 9039-9049 (resolution 1920x1080) and the current D9/D10 edition called mkIII with type no 905x,908x,907x and 911x). The first one came with the BeoSystem 2, the HD-Ready version with the BeoSystem 2 mkII (w/DVI) and the current is driven by the great BeoSystem 3.
    Roger
  • 06-07-2008 12:02 PM In reply to
    • tIRED
    • Not Ranked
    • Posts 32
    OK. Thanks. As I understand your post there is no (non HD) version of the 50" plasma. They first one  (called D6) is 1366x768 (hench supporting 720i/p) and the later (D7, D8, D9/D10) are all 1080i/p. Correct? Where (exaclty) can I find information about this in the products-section? When choosing Televisions-Plasma-Beovision 4 I only find information on the "old" one (not stating "which one it really is) and all being based on the old BS2-setup. Not a word on the current "situation" with BS3 and so on...
