Latest post 06-02-2008 8:47 AM by KingStreet. 2 replies.
Page 1 of 1 (3 items)
  • 06-02-2008 8:25 AM
    Beovision 7 DVB-T Module
    If I add a B&O DVB-T (Freeview) module in my BV7, will the channels appear under DTV or TV.
    If they appear under DTV, I suppose I'll have to assign my set top box to V.AUX or something like that.
     p.
  • 06-02-2008 8:38 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Beovision 7 DVB-T Module
    They will appear under DTV, which prevents you from using the DTV button for anything else. V.Aux is what's usually used.
    The best solution around this is the Beo5, which allows you to call 'V.Aux' whatever you want.
     Weekly top artists:
  • 06-02-2008 8:47 AM In reply to
    Correct  - the dvbt module occupies the DTV command.
    Ideally a Beo5 is used in this set up, so you're not using a digibox via V.Aux all the time, which involves the list button.
     Regards
    David
    Bang & Olufsen of King Street - Manchester,UK. SKYPE - beokingstreet
