Hi
I need some help with a connection problem, I have a Beosystem 2 with a Panasonsic PW4 series plasma which dates from 2002. I have the BS2 connected to the RGBHV inputs as this is what the system switches the screen to via the RS232 data lead when I select any of the video sources. The screen is set to D5 in the service menu as this is the closest to my screen.
I have connected the my mac mini to the VGA input on the screen , but I am unable to get the screen to switch to VGA at all using the PC from the Beo4, I have tried different settings in the service menu but I am unable to highlight or change the selection for the VGA in the menu. I can select PC using the original remote but obviously i would like just use the Beo4.
So if any of you BV4 or BV5 owners that have a early panel and use the VGA input I would love to know how you get it working etc.
Thanks in advance
