Latest post 05-25-2008 6:37 PM by Medogsfat. 1 replies.
Page 1 of 1 (2 items)
  • 05-25-2008 6:31 PM
    • geomich69
    • Not Ranked
    • Joined on 04-13-2008
    • THESSALONIKI , GREECE
    • Posts 22
    which remote for beomaster 5000?
    any ideas on this topic? is a beolink 1000, or beo1 suitable to control this? how about beolink 7000?
    I'm interested because I would like to buy a beomaster 5000 for a bedroom!
    xx,
    George
    Filed under:
  • 05-25-2008 6:37 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: which remote for beomaster 5000?
    Very limited I'm afraid. You have only 2 options.
    1. Terminal 5000
    2. MCP 5000.
    Nothing else will work as the codes on the Beomaster 5000 differ to the others you mention especially the Beo1 which is a video only terminal designed for use with the Beovision 1 and is a complete waste of space frankly,
    Chris.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
